RCU Forums - View Single Post - Circuit primming in a P160SX
Old 04-04-2011 | 08:09 AM
George
My Feedback: (57)
Default RE: Circuit primming in a P160SX
ORIGINAL: FILE IFR
ORIGINAL: jetnuno
Hi
Thanks. I have tested this and the pump runs ok, but the fuel valve does not open.
Check to see your solenoid valve in plugged into the ECU at the correct polarity..... Also, check that your main (manual) fuel valve is open.
.... Like Countryboy said, disconnect your fuel line to the engine to prevent flooding it and causing a wet start on the first start-up.
Also DOUBLE check that it is plugged into the "correct" set of pins. (I've done that before)[&:]
