RE: Enya 45CX dies?
Dar and Scotty, here are some pics to illustrate what is being said. If you want to tame the very loud Enya muffler an MDS .48/.68 muffler will bolt right on. The one pictured is a .58 muffler. MDS varied the length to accomodate different engines. The .48 muffler would about .5" shorter than this one. Interestingly the fuel does not flow through the carb barrel, the barrel resides about 3/32" from the end of the carb body and the fuel flows around the end of the barrel in the passage in picture #2 then in through the metering slot.
