RCU Forums - View Single Post - SdKfz 250/9 project
Old 04-05-2011 | 09:08 AM
  #61
CountChocula's Avatar
CountChocula
Default RE: SdKfz 250/9 project
I was able to spend some time on the HT over the last couple of days. I accomplished quite a few things with still more to do.
1. Realizing that I needed more room (especially for the turret traverse mechanism), I begrudgingly decided to raise the ceiling of the HT enough to house all the components I needed. I didn't want to do this since it changes the look completely, but it was needed to make this work. I thought about following the 60 degree angle of the side plating, but this meant I had less top surface area for the turret and would have caused a major turret overhang problem on the sides. So I chose to just go vertical and live with it. To accomplish the lift, I used some evergreen .125 stock and basically built a frame around the top.
2. I also cut out the MG slot and sighting scope slots on the turret. I then made my first pass at a 18th scale 20mm cannon. It's not perfect, but I think it will work for now. The plan is to mount the emitter either under the MG, or, possibly under the 20mm cannon if I can get elevation to work. I don't have much room but am considering some sort of server type of elevation.
Here are some pics.
Dave
ID:	1589564   Click image for larger version
ID:	1589565   Click image for larger version
ID:	1589566   Click image for larger version
ID:	1589567   Click image for larger version
ID:	1589568   Click image for larger version
ID:	1589569   Click image for larger version
ID:	1589570   Click image for larger version
