RCU Forums - View Single Post - Glow to electirc conversion
Old 04-05-2011 | 01:04 PM
scooterinvegas's Avatar
scooterinvegas
Default RE: Glow to electirc conversion
Need my info on the type of plane, weight, prop size and what type of flying you want to do.
I would think something in the .32 size would work.
E-flute power .32 or Scorpion 3026-890 with a 60-80 amp speed controll on a 4 cell battery. You can pick a higher Kv motor if you want the stick with a 3 cell.
Here is a chart that shows all the prop data for the Scorpion 3026-890. You can see the amp load, thrust and wattage pulled using APC props. These charts are spot on in my test with there motors.
http://www.rcdude.com/servlet/the-te...6890Chart/Page
