ORIGINAL: extra person
ok i found it its a routan quicky 1/4 scale now looking to go to 1/3 scale
Multiply the current plans by 133%. Now having said that if the plans are already
36" wide that will make them 48" wide. Get in touch with Dennis through the above
mentioned e-mail and he will get you going toward the enlargement, he is able to print
up to 42" wide and is very good at what he does, I for one am a very happy customer.
As stated above you will also have to do some resizing on the materials used in the
original plans, not a hard thing to do if you have scratch built before, just round up or
down to the nearest size balsa, spruce, plywood availalble through your chosen suppliers.
I can recommend 2 very good foam core cutting specialist, Don @ Eureka Aircraft in Arkansas,
www.eurekaaircraft.com and Bob At Flying Foam:
www.flyingfoam.com/launch.html, both
are very good with foam cutting and very reasonable on pricing.
Contact Dennis:
[email protected]
Bill D.
