RE: I Saw it! TF 60 Size Corsair ARF!!!!!
Hmm - the engine power range is pretty small, especially for the wing loading they list. I wonder if this plane has beeen redesigned so it won't accept/hold up to 1.20 4 strokes? .90 2 strokes? DLE 20?
Engine: 2-stroke .61-.65 cu in or 4-stroke .91-.95 cu in
Propeller, fuel, building and field equipment
SPECS: Wingspan: 62.5" (1590mm)
Wing Area: 699 in² (45.1 dm²)
Weight: 8.5-9.5 lb (3.85-4.3 kg)
Wing Loading: 28-31 oz/ft² (85-95 g/dm²)
The kit specs say:
Wingspan: 62 in (1575mm)
Wing Area: 700 sq in (42.5 sq dm)
Weight: 7-9.5 lb (3180-4310g) Fuselage Length: 48.5 in (1230mm)
Requires: 2-stroke .61-.90 cu in (10-15cc) or 4-stroke .91-1.20 cu in (15-20cc) engine & 4-7 channel radio with 4-7 standard servos
Ed
