RE: Ultracote seams
I learned many years ago that no covering is "fuel proof" on its edges and that includes old and new Monokote.
When it was available, I used to seal the edges with K&B Superpoxy clear while using a very fine paint brush. I put on the very minimum of clear paint. One had to keep in mind where the clear paint was when reheating/ironing the covering, or one would be very sorry. Still, it was the best deal going.
Why Superpoxy clear? Because it was very close to being truly clear - but not quite and not yellow. It had a reddish tinge to it which was mostly unnoticable.
I have also used water based polyurethane clear with great success. The secret is to use the minimum amount necessary. Yes, it is tedious work, but it works!
Ed Cregger
