ORIGINAL: mattingham I have a new Aurora with Spectra Pro 72 MHz module. My first impression is that half the manual is about using the 2.4 Ghz system. That aside, I don't see any information about the ID setting module that came with it. So I don't know if I'm supposed to use it or if its for the 2.4 system.
The Aurora
manual coversthe Aurora 9 with both 2.4Ghz and the 72 Mhz modules installed.
There are also separate manuals for both modules.
My understanding is that the Aurora was only available with the 2.4GHz module in USA and that the 72MHz Spectra Pro modulewas only an optional extra at this time.
There is no mention of a "IDSetting Module" in the
Spectra Pro 72MHz manual, nor have I seen one here.
72 Spectra Pro module manual, as lodged with FCC, under range test:
<span style="font-size: smaller">"Warning!
- Do the range check before each flying session to confirm the
radio system is working properly.
- Do the range check before the engine or motor is started."</span>
amend to read
- Do the range check with the engine or motor running and cycled up <> down or add
"and repeat with Engine/Motor running which will highlight and vibration/electrical problems"
Please start a separate thread with a picture and further detail of that "IDSetting Module".
This partcular thread is intended for answers to questions posted in many various forums.
Please post further questions relating tonew topicsas a newthread at
<u><font color="#00265e">Hitec/MultiPlex Radios- Ask Hitec Customer Service</font></u> ,
Thisensures new questions will stand out and be seen and readby all qualified persons.
Later, have this a.m. learnt the Aurora is
now available as TX with a 72 Spectra Pro module and Freedom 9 Sythesised RX only.
The "IDSet up Module" is detailed & additional 9S pictorial manual at:
<font color="#22229c"><u>Hitec - Synthesised HSD-09RQ (Freedom 9S) Manual and set-up </u></font><dt>&<a href="http://www.rcgroups.com/forums/showthread.php?t=1249612#post15161915" last_visit="1226179442" last_modified="1226179406" add_date="1218663949">
<u><font color="#00265e">Hitec - Synthesised HSD-09RQ (Freedom 9S) Manuals, Pinouts and set-up</font></u></a>
Alan T.
Alan T.</dt>
