RCU Forums - View Single Post - Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
Old 04-07-2011 | 01:34 PM
  #116
A.T.
Default RE: Aurora 9Ch, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips.
ORIGINAL: mstcitabria73 Using a Miracle Dual switch, 2- A123 2300ma batteries, Wik's IBEF on a DLE 55,Aurora 9 w/9 CH Optima.Would like info on the best way to to run the 2 batteries into theOptima9, without damaging anything, any suggestions, Thanks.
1. Miracle Switch posts 1,4 & 8.
Miracle Switch Problems posts 12, 60 & 63
2. WRC Wike R/C Products IBEF Ignition Battery Eliminating Filter - Manual, should not present any problem set up either via a spare channel or in the manual setup.
<span style="font-size: smaller">following may also assist:
</span><span style="font-size: smaller"><font color="#22229c">Optima Transceiver (RX) - Battery set up for Nitro/Gas models</font></span><span style="font-size: smaller"> #1 - caution re NiMH &amp; <span style="color: #ff0000">Alert re LiFE.
</span></span><span style="font-size: smaller"><font color="#22229c">Optima Transceiver (RX) - Dual or Multiple Batteries may be installed</font></span><span style="font-size: smaller"> for redundancy, even one for each servo.
</span>Please post further questions relating tonew topicsas a newthread at
<u><font color="#00265e">Hitec/MultiPlex Radios- Ask Hitec Customer Service</font></u> ,
Thisensures new questions will stand out and be seen and readby all qualified persons.
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
<span style="font-size: smaller">(quick search = Ctrl+F)</span>
