RCU Forums - View Single Post - Flaps or flaperons?
Old 04-07-2011 | 03:52 PM
cfircav8r's Avatar
cfircav8r
Default RE: Flaps or flaperons?
Definitely make sure you are using a low pitch large diameter prop and a good low idle. The other thing to do is get up high and practice trimming the plane for a nice slow stable glide. This will allow you to set the trim and use throttle to adjust your descent. A good slow stable descent is the key to a good landing for a Cub.
