RE: ELECTRONICS SETUP on GAS PLANE
Back to the OP's question. Your entry into gas MANDATES a range test both prior to the maiden and after anything is changed on the airframe. RFI can desense the receiver with noise and reduce range. RFI is not something you've had to be concerned about, but must now be cautious about.
Enjoy the cheaper fuel, easier clean up, lighter flight box but don't forget to range check.
