RE: ELECTRONICS SETUP on GAS PLANE
HI
DO NOT USE metal push rods from inside the fuse to the engine-nyrod is good
keep the receiver about a foot from the engines ignition
both to prevent radio noise that is interference
keep the RX antenna away from all other wiring in the fuse RANGE CHECK with engine running
a fuel dotmakes for easy fueling with gas engines
follow the directions regarding the ratio of gas to oilon the 2 cycle oil you choisei like -lawn boy 30-1 for break in then go to a fully syn oil to reduce engine wear for the long run
just my .02 cents REGARDS TONY
