RE: NEW DLE30!
Usually adding fuel will make it rougher. Is this your first gas engine? If so you will find thery viabrate much more than a glow engine because the power pulses are much stronger. Once tuned correctly I find the 30 rather smooth. The so called factory setting are only to get it running. both needles will need to be adjusted for proper operation.
