RCU Forums - View Single Post - set up problem?
Old 04-08-2011 | 05:06 PM
tacx's Avatar
tacx
Default RE: set up problem?
You say you closed the low end needle and things improved, but when you throttle up the engine hesitates, but does get to wide open throttle. You need to close it a bit more. If you throttle up and it quits instantly then you would be to lean and you would have to OPEN the low end a bit.
