RCU Forums - View Single Post - propane issue on Jetcat.........
Old 04-09-2011 | 04:49 PM
trioval00
My Feedback: (17)
Default propane issue on Jetcat.........
ok, before I send this back to Jetcat, I thought I might ask the pro's here. Tonight I wnated to fire up my P-120 and just make sure everything was working good before I head out to the field. I flew it about 4 maybe 5 months ago, long hard winter.
Problem I am having is the propane line inside the can must be 80% blocked. I did a bypass around the propane valve and fed the propane direct into the 120. I can hear it spitting and sputtering, not a clean spray. SO, other then sending it back, is there anything I can do that might free up the blockage? I did try to blow compressed air in the line, but no luck.
Mark
