RCU Forums - View Single Post - HL solder quality ?????
Old 04-09-2011 | 10:24 PM
HondoBob's Avatar
HondoBob
Default RE: HL solder quality ?????
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-size: 9pt">I use a common Weller 15/30 watt switchable soldering iron for my small scale projects.<span style="mso-spacerun: yes"> </span>Learning how to properly clean, tin, and &ldquo;whet&rdquo; a solder joint using the proper soldering tip for the taskis always a handy skill set to develop.<span style="mso-spacerun: yes"> </span>Stay away from the high power soldering guns unless you&rsquo;re making 00 gauge power cables (lol).<span style="mso-spacerun: yes"> </span>Practice, practice, practice makes perfect, though having good instruction is always a plus.</span></p>
