help settingup skylark 56
You lucky dog! That airplane is a classic.
Any 40 - 46 size engine will do fine. engine can be anywhere from zero-zero to 2 degrees right and down.
Start with it balancing about 1/3 back from the wings leading edge, and adjust as needed (unless someone out there has the actual plans showing the exact CG).
