RCU Forums - View Single Post - Laser 3D
Thread: Laser 3D
Old 08-16-2003 | 07:36 PM
  #43
Eugoogoly
Default Laser 3D
got it sorted now with only a little of paper stuck to the ailerons.
but ive got a problem with the fuselage - if you could refer to step 37 of the instructions - it says continue by fitting the side reinforcement. is this just the 6x6mm balsa spars running alont the inside of the fuse or is there something else im not getting?
wish these belgiums could have used colour ink. might be able to work out the pictures better.
anither q. when it says to sand the hinge edges of the ailerons, how much should i take off or should they just be rounded?
thanks
