RCU Forums - View Single Post - Perplexing engine trouble
Old 04-11-2011 | 06:28 AM
Gray Beard
My Feedback: (-1)
Default RE: Perplexing engine trouble
You have an air leak someplace in your system. Fuel today has an anti foaming agent in it and fuel foaming is pretty much a thing of the past. Check your lines, and bung. If you still have a problem then check the lines inside the tank. By putting your tank under water and pressure testing it you can usually find the leak right away.
