RCU Forums - View Single Post - Laser 3D
Thread: Laser 3D
Old 08-19-2003 | 02:29 PM
  #80
southern_touch9
Default Laser 3D
The plane looks good so far. Do you have the canopy glued down already?? If not you better tack it on to the airframe with some tape. Failure to do so could result in a ruined canopy. It doesnt come precut for a reason, and that reason is with that grade of plastic it will loose its shape if its not glued into place. REmember all the suggestions on the tail. If you build the tail and elevator stock you will have problems down the road. Anyone who hasnt made a modification on the tail and dont have a problem isnt flying 3D like they should. A parachute will rip the horizontal off. You can either build a solid elevator, frame up the elevator and sheet it or put gussets in EVERY place where there is a corner. On your horizontal you may want to either frame it up and sheet it or use kevlar flying wires. I say kevlar b/c its the best quality and the lightest. Another thing about the horizontal is that on my newer laser3D I have noticed the horizontal is coming unglued. Its important to glue it in well, and I am going to go back with two small pieces of tri stock on the under side of my horizontal stab.
