Hi Bart,
that sounds suspecious !!
If there is no obvious faults on the cable, there must be some kind of fault on the device itself, can you maybe check if the cable connections are "solid" ?
If they look ok, I guess your best bet is to contact the place you got them from (I'm just the developer
