RE: DLE 30 stalling
Rear carb or side carb? The side carbs are known to have the issue, hence the revision change & rear mounting kit.
If it's rear carb, you likely have a diaphram pressure issue. Tap the cover and run a line into your fuse (pill bottle optional).
