RCU Forums - View Single Post - Engine Vibration
Old 04-12-2011 | 02:47 AM
airbusdrvr
Default RE: Engine Vibration
If the prop "IS" balanced using a prop balancer and the engine bearings are assumed to be good in the new engine, then you may have a loose firewall or loose engine mount. Since the issue is present with two engines and props, it is most likely airplane related.
