RCU Forums - View Single Post - C/G for Tandum Wing
Old 04-12-2011 | 06:48 AM
Lnewqban's Avatar
Lnewqban
Default RE: C/G for Tandum Wing
Jeff,
The principle is the same: find the center of pressure where the lift of all the surfaces is considered applied, then select a stability margin and locate a safe CG.
This article may help you:
http://www.geistware.com/rcmodeling/...calc/index.htm
Now, the incidence angle of each surface is another matter and is related to longitudinal dihedral.
Andy Lennon;s book has a good description of designing a tandem plane.
