RE: Sig Wonder Build
Spent all yesterday evening setting up the radio and adjusting all the control throws. Set the end point adjustment on the throttle. That was a little tricky because my new radio has a weird throttle trim that only goes down, doesn't go up, so I had set the trim down 30 clicks and then go back in to programming and set the EPA so that I have room to open and close the throttle with the trim. Took me a while to figure that one out.
Adjusted ailerons up and down 5/16" and elevator up and down to 1/4". Doesn't seem like enough but I'm taking you guys word for it. I did not know how much expo I would need so I set two different rates to the dual rate switches so that I have 50% on both ailerons and elevator with the switches down and 30% on both with the switches up.
Made the little balance stand like it shows in the instructions. I went ahead and added one 1/4 oz weight to the firewall to get it to balance on the marks, but I may take that off, we'll see.
