RCU Forums - View Single Post - How about this for a trainer
Old 04-13-2011 | 01:06 PM
hyrulejedi86
Default How about this for a trainer
I've using a trainer for a while now, clearview RC sim. I found this beginner plane (interestingly both in real life and on the sim) Iwas thinking of getting and have two questions about it.
Here it is:
http://www.nitroplanes.com/60a-dy892...y-rtf-24g.html
I like the looks of it, it flies well on clearview and according to the stats it uses a 3s20c 1800mAh battery.
Does anyone have this plane? If so would a 2200mAh battery work in it without completly throwing everything off balance? Interestingly Ihave some 1300mAh 30C batteries that can output the same Amps as the recommended battery so I could use them if I can't use a 2200mAh. I eventually want to get an A-10 airhog whichuses 2200mAh batteries, this way Idon't have to buy a bunch of different capacity batteries.
Input?</p>
