ORIGINAL: dirtydingus
Hey Dave
I am using the felt clunks in both tanks and the wing tank is completely empty after draining. The main tank however has fuel that you can see up in front. I realize it's probably not a problem causer it's just a little unsettling to drain a tank and still have a pint of fuel sloshing around. Seems like comp arf would have remedied the issue early on.
On a different note, I am doing the maiden tomorrow. Overall I am very happy with the plane and would consider it a fine ARF.
Jim
Why not drain the main tank first and wing tank last? That way you will get every drop out of the main tank?
Mav
