RCU Forums - View Single Post - Twister xtg Pro problems.
Old 04-14-2011 | 06:00 PM
nitrosportsandrunner's Avatar
Default RE: Twister xtg Pro problems.
ORIGINAL: digitaldetox
yeah kinda. im running a 2s lipo. also does it have a automatic cut off for lipo? becuase after i run it and it loses power my lipo is under 3.7v. its like 3.4v.. anyway yeah foward and break works.. but no reverse. im messing with it as we speak. also where can i get better gears? anyone know.. where i can get parts for this thing? do anuy other brand parts fit on it? i didnt recieve any parts catalog or anything with my redcat.
here is the online manual: http://content.yudu.com/Library/A1r8...-XTG-Brushless
count the # of teeth on your stock pinion gear(on the motor shaft)
if its 21 tooth, then you can get the 23 tooth pinion from redcat. im not certain which one came stock. but i would think that the buggy came stock with the 23 and the truggy with the 21. since i believe the buggy has smaller rear tires.
anyway, going up 2 teeth on the pinion will increase to speed.
