RCU Forums - View Single Post - ALPHA 60 ENGINE ALIGNMENT
Old 04-14-2011 | 06:46 PM
ec121
Default RE: ALPHA 60 ENGINE ALIGNMENT
The Alpha 60 has a lot of positive incidence in the wing for beginners to be able to fly slowly. The downthrust might be to counteract that. You can also shim up the trailing edge of the wing to reduce the amount of positive angle. The angle is the reason for the excessive down trim. It will also probably really climb at full throttle.
