RE: Help with Sig 1/2A Skyray
gcb - Thanks for the tips on the pushrod locations! The instructions say where to put it on the control horn (bottom hole, the middle hole is for stunting according to SIG) but the instructions also picture the outer hole for the bellcrank, I'll get that moved before Igo to fly again.
What do you do to get the lines tied evenly? I was intrigued by the Sullivan handle because it was adjustable but now with the smaller 1/2A handle I have to tie it perfectly so it'll work well and that took some work.
I think I have the alignment pretty good between the wing, stabilizer and rudder but the wing itself came warped a bit. I'm also thinking about getting a Lil' Wizard from Brodak. I hear these are lousy for stunting but good for learning to go around in a circle.
