RCU Forums - View Single Post - Help with Sig 1/2A Skyray
Old 04-16-2011 | 08:28 AM
gcb
Default RE: Help with Sig 1/2A Skyray
ORIGINAL: jpuke
...What do you do to get the lines tied evenly? I was intrigued by the Sullivan handle because it was adjustable but now with the smaller 1/2A handle I have to tie it perfectly so it'll work well and that took some work.
Most 1/2A handles have two or three sets of holes for spacing and a small knob (or another device) in the middle. Assuming dacron or fishing line, you run the lines (uncut) through the handle and to the plane...I like to use clips on the ends. You wrap the center of the lines over the center device and adjust by moving the loop as needed.
George
ID:	1594615   Click image for larger version
