RCU Forums - View Single Post - Aurora 9 Manual Index
Old 04-17-2011 | 09:12 AM
Wayne Miller
Default Aurora 9 Manual Index
Hi,
The Aurora 9 manual has a good Table of Contents, but sometimes I still find it a little difficult to find specifically what I need.
As a result, I went through the manual and put together an index of key words. Some of the items are listed twice or more using different names - such as EPA which would also have a listing as End Point Adjustment.
The reason for doing this to try and cross reference all the different common names so when you want to look something up, it should be easier to find.
This is my first draft, if you have any suggestions, additions, or changes you would like to see incorporated. Please let me know.
The index is attached in PDF format. If you print it two sided, you can trim it and it fits nicely into the back of the manual.
I have also put together a printable programming chart to help find your way through the menus and you can find it here:
http://www.rcuniverse.com/forum/m_10...m.htm#10481073
Hope you find it useful, if so, please let me know.
Fly4Fun,
Wayne
File Type: pdf
