RCU Forums - View Single Post - Need a recommendation...
Old 04-17-2011 | 11:05 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: Need a recommendation...
ORIGINAL: Phoenixangel
Go with the ST or TTPRO engine, either will turn a 13 very very nicely for you, reaching your speed goal. Both of them are great with castor. Even the G.75 will turn a 13x8-9 with very impressive numbers. I am not an O.S. guy either.
I would rather have new stuff to build with the $$ I save on tiger type engines. But that is just me.
You will hit your goal with either of the more affordable engines with your boat under 7 pounds. I would however go with the .90 range engines turning the higher pitch 13's. I don't think a .60-70 will produce the thrust you need with any prop.
I looked into the G90 and Pro 91... Is there that big of a difference in quality or is there something that much more special about the TT Pro to warrant being $100 more than the G90? Moreover, I had seen several S90K's for sale for less than $75. Some have said the S90's were better than the G90's.. Any thoughts?
