RCU Forums - View Single Post - AMR TRAINER 20
Old 04-17-2011 | 04:37 PM
RSABY50's Avatar
RSABY50
Default RE: AMR TRAINER 20
I found a liitle mistake at the time of the elevator servo under the stab, It's not a big problem but at this location, the fuselage is not widht enough to accept a standard size servo so you can use a slim one or make the little change I did on mine. Look at the pictures and you should understand what I did and the problem was set.
ID:	1595305   Click image for larger version
ID:	1595306   Click image for larger version
ID:	1595307   Click image for larger version
