RE: Need a recommendation...
An airboat is very draggy compared to an airplane. From your figures, it seems clear you're stalling the higher pitched smaller diameter props to the point where RPM simply doesn't matter.
You need a lot of static thrust, and that means playing with larger diameter, lower pitches
