Trouble setting up flaps
I have a Blaster 2 DLG glider which I am currently flying without flaps. Now I would like to enable the flaps but I am having trouble getting them to work.</p>
I am using a Spektrum DX6i transmitter and AR6100 receiver. The instructions say I should plug the left servo into the AUX1 port and the right servo into the AILE port. This I have done. The aileron stick now controls just one aileron but the flap switch does nothing. If I activate the DUALAILE function in the WINGTAILMIX menu I then get the aileron stick operating the ailerons as flaps, but the flap switch doing nothing.
It's clearly the flap function that's causing the problem but I can't work out how to solve it. I've not used this function before so i guess I'm missing something obvious.</p>
Any ideas?</p>
