RCU Forums - View Single Post - Trouble setting up flaps
Old 04-18-2011 | 06:33 AM
BuschBarber
Default RE: Trouble setting up flaps
ORIGINAL: ButteredCat
I have a Blaster 2 DLG glider which I am currently flying without flaps. Now I would like to enable the flaps but I am having trouble getting them to work.</p>
I am using a Spektrum DX6i transmitter and AR6100 receiver. The instructions say I should plug the left servo into the AUX1 port and the right servo into the AILE port. This I have done. The aileron stick now controls just one aileron but the flap switch does nothing. If I activate the DUALAILE function in the WINGTAILMIX menu I then get the aileron stick operating the ailerons as flaps, but the flap switch doing nothing.
It's clearly the flap function that's causing the problem but I can't work out how to solve it. I've not used this function before so i guess I'm missing something obvious.</p>
Any ideas?</p>
If that radio has the Flapperon mix or Wing Type, you should be using that program. It allows you to use Ailerons as Flaps. If that radio has Flap System, it needs to be enabled.
