RCU Forums - View Single Post - Trouble setting up flaps
Old 04-18-2011 | 06:54 AM
BuschBarber
Default RE: Trouble setting up flaps
ORIGINAL: ButteredCat
BuschBarber,
From the instructions:
<font size=''2'' face=''HelveticaLTStd-BoldCond''><font size=''2'' face=''HelveticaLTStd-BoldCond''><p align=''left''>'Dual Aileron Wing Type Selection</p></font></font><font size=''2'' face=''HelveticaLTStd-LightCond''><font size=''2'' face=''HelveticaLTStd-LightCond''><p align=''left''>Dual Ailerons require the use of one servo for each aileron and allow the use of ailerons as flaps or spoilers. This</p><p align=''left''>function also allows the precise independent adjustment of up and down travel, and independent sub-trim and</p>
differential of each aileron.'
So it's clearly possible and I've followed the instructions, but still no joy with the flaps.</p></font></font>
I have two JR XP9303 radios. I use the Flapperon program to mix the Right and Left Aileron servos as Ailerons and I disable the Flap component by Inhibiting the Flap System and Flap Trim. Some use Differential Aileron to mix the two Aileron servos. Each radio can have different programs to accomplish this task.
In your case, you are successfully mixing the two servos using Dual Aileron, but you cannot get them to act as Flaps. Apparently, the Flap System is not enabled. I don't remember if your radio has Flap System. It should have some reference to it in the manual. I do not have time to download the manual and look it up, right now.
