RCU Forums - View Single Post - engine cooling
Old 04-18-2011 | 07:58 AM
iron eagel's Avatar
iron eagel
Default RE: engine cooling
ORIGINAL: Sport_Pilot
Why not simply baffle the engine so that the air that comes around the dummy engine is forced from top to bottom and out? I would only take a bit of plywood, balsa, and perhaps some plastic or fabric to make the baffles. You should have plenty of air without a fan. Glow engines just don't generate enough heat to get that fancy.</p>
This is the way to do it!
