RE: Flaps or flaperons?
1976kjell; try this, slow field passes a few mistakes high as slow as you think the model can manage with a shallow decent.
You'll likely find you can get it to slow down in a pass quite a bit. Look at several of the other clipped wing cub videos doing single wheel landings and touch and goes......
Unless you're very heavy you should be able to translate a slow pass into a slow landing.
