RCU Forums - View Single Post - Spray Bar alignment
Old 04-18-2011 | 11:39 AM
Mr Cox's Avatar
Mr Cox
Default RE: Spray Bar alignment
On ST carbs you rotate the spraybar to tune the mixture of the midrange.
PAW has two wholes in their spray bar so that none is pointing straight down.
So it seems that most proper manufacturers are well aware of these effect, while the low budget copies might not be. On the other hand, there is still a low pressure when pointing straight down, just not quite as good as the one around 90 degrees.
