RCU Forums - View Single Post - Trouble setting up flaps
Old 04-19-2011 | 07:24 AM
BuschBarber
Default RE: Trouble setting up flaps
The manual for your aircraft should give you specs on Control Surface defections. Climb to a safe altitude,slow the aircraft down, deploy the Flaps, and determine how much Elevator Coupling you need. Be careful not to Stall the aircraft. Every aircraft is different.
With my H9 P47-150, I was able to use the same valued that another club member used on his P47. We both had the same radios.
