RE: pusher gyro's
Specific to a Bensen Gyrocopter the mast has a 9 degree tilt to the rear. After the machine is built it needs to be hung tested from the rotorhead and with a 50 % load of fuel the mast should have a tilt of between 2 and 6 degrees to be properly balanced for flight.
