ORIGINAL: Bob Pastorello So, Alan, I think you told me from these links - NO - I don't *need* to upgrade, but YES - I will need to rebind every receiver as a precaution if I choose to update the module. Is that the bottom line?
Hitec 2.4 GHz AFHSS Equipment Update Manual
'WARNING
After the firmware upgrade, you must perform a range check and full ground before the first flight. "
IDreset is not mentioned as being necessary.
However, with update toV3.01, given the changes, and as one of the older generation who has experiencedchanges to firmware in different equipment with interesting results over many years,
decided it was prudent to rebind my Optima transceivers.
Thisso as to also familiarise myself with the new scan function procedure - whichthen requires all other Optima/Minima then be re-set (rebound) to the module's new ID code.
Alan T.
