RCU Forums - View Single Post - DLE 111
Thread: DLE 111
Old 04-20-2011 | 02:39 AM
FlyerRick's Avatar
FlyerRick
Default DLE 111
<span style="font-size: larger"><span style="font-family: Tahoma">Ok, got a DLE 111, 15 flights, running good grade standard 91 octain pump gas, 40:1 mix with "Redline", the engine has been flawless anda dream so far with loads of power...last time out, got my first flight in, alls good...second flight, the engine would start, idle, and run up to half throttle just fine....try to give anymore than half throttle the engine will choke out an die??? Tryed for an hour, pulled, checked and changed the plugs, checked my fuel lines and supply, checked the carb settings, same thing...starts, idles and runs great up to about half throttle, then chokes out and dies unless you bring it back to half throttle. Up to half throttle, alls good! I'm open to all help and suggestions here??? Thanks </span></span>
