RCU Forums - View Single Post - Landings - How Do You Do It?
Old 04-20-2011 | 09:20 AM
billd76's Avatar
billd76
Default RE: Landings - How Do You Do It?
ORIGINAL: bigedmustafa
I've always been a big proponent of practicing 90 degree turns and using them on final. We have a 500' long paved runway that many club members seem to have difficulty hitting. The guys that do land consistently and practice touch-and-goes on a regular basis all seem to use the square turn to set up their final approach.
A good 90 degree turn on final, as opposed to just trying to curve around into the runway, basically lines you up perfectly to land. You don't have to manage a lot of minor course corrections or adjustments to straighten yourself out, except in case of a cross wind. Instead, you can focus on your glide path and throttle management, and it's much easier to land smoothly on a consistent basis.
Once you turn to your final approach, hitting the runway should be a foregone conclusion. The 90 degree turn is the simplest way to achive that.
Agreed, but at first, where exactly to initiate that 90 degree turn can be an issue. At least it was for me.
