RCU Forums - View Single Post - U-Can-Do 3D .46 with OS .46 2-stroke
Old 04-20-2011 | 02:04 PM
zacharyR
Default RE: U-Can-Do 3D .46 with OS .46 2-stroke
ORIGINAL: ES CONTROL
Hummm a OS AX 46 . the hp is the same as a LA 65 ,or a 4Stroke 91. I do not think a AX 46 will have the same tork. <div> I know a 4 pitch prop will give you unlimited vertical and save the plane from flying to fast, but you will need a 5 or 6 pitch to do a nicer knife edge.</div><div>
</div><div>Yes ! Do IT! Note : this plane will last longer if 3 D rates are not used .( it will be easier to learn to hover on high/med. rates anyhow.)</div>
this is false
fly the plane on high rates just make sure your expo matches your skill and preference
if you follow 3d alot you'll find some times ppl crash do to being on Low rates and not having the throw in a stalled type flying situation to recover ,
for example recovering from a Hover . you might find yourself in a inverted harrier and you want enough to be able to hold that HIGH AOA . on tell your at a safe attitude .
the 46 ax with whatever prop isn't going to you unlimited vertical in this airframe . but that doesn't me it' isn't still a fun flying plane that is easy on the sticks
