RCU Forums - View Single Post - Throttle servo glitching
Old 04-20-2011 | 06:34 PM
bjor's Avatar
bjor
Default RE: Throttle servo glitching
ORIGINAL: niteowl5001
Hello guys, I have a BME 50 in a Katana. At half throttle the ignition servo which is a hitec servo is fine. If i exceed half throttle the servo glitches. It drops in and out of full throttle and where have the throttle stick set on my radio. I've swapped the servo and the c&h ignition. Any ideas????? Thanks
John Franklin
Sounds like you are getting RF interference. Just check these few things:
NO metal to metal between the sero and throttle - always use nylon rod etc,
Make sure the cap is fixed tight over the plug - push the cap on as hard as it will go, all the way over the hex base of the plug.
Seperate the Rx from the CDI - make sure there is as much gap in the installation as possible to suppress any interference.
Regardless of 2.4, 35, 36 or 72mHz, these are some of the basics when running gas engines.
Good luck.
