RCU Forums - View Single Post - Dirty Birdy Instructions Update
Old 04-21-2011 | 09:54 PM
immelman50
Default RE: Dirty Birdy Instructions Update
Hi Dave ,
Thanks so much for the effort you put in by posting your building notes. I used them extensively while I built my Dirty Birdy from the Bluejay kit. I found the kit to be well done, good balsa and definitely old school in the building techniques. Your notes on incidence and the 1/8 longer stab on the plans really helped avoid inaccuracies. Mine has some Rhom retracts, an OS 61 FSR with a Supertigre pipe and the fuselage and vertical stab are glassed and painted. All up weight ( with 4 ounces of tail weight) is 7 pounds 3 ounces. I await decent flying weather here in northern Minnesota to maiden it. Thanks again!
Chuck
ID:	1597347   Click image for larger version
