RCU Forums - View Single Post - hobbyking experience?
Old 04-22-2011 | 06:46 AM
billd76's Avatar
billd76
Default RE: hobbyking experience?
ORIGINAL: goirish
ORIGINAL: billd76
s. And with the rain and the wind we're getting these days in my area, it will be Friggin July before we get a good flying day anyway!!! So I can wait!!
Boy are you lucky, it's looking like August before we can fly again. I get it shipped quicker from HK then I do some of the stateside suppliers. BTW, Bill, I think you need a few more planes in your hangar.
One of club members put the HK orange RX in a glider with no satelite and took is up almost out of sight and still had full control.
Gorrish!! How have you been? Yeah, I do need more planes! What I really need is time to fly them! I've been trying without alot of luck to get the ST italian 90 to run on my twist 60. Not having any luck with it. May get the JBA 15 cc gasser and put in it. I need to build an engine test stand so I can work on it easier, can't seem to get it to run right, mid range is bad, transition is bad, full throttle is great. When I set the high end, to where I think it should be, the it stalls on the pinch test, when I set the high end where it passes the pinch test, it will start to gurggle. and loose RPM's. Gotta an air leak somewhere I think. replaced the Oring at the base of the carb, no difference. Well, I'll either figure it out or get a new engine or sell just sell the plane!!
